Hi all,
how to collect grout tube when i select the wall.
Wall is hosted object , how can i get the grout tubes.
waiting for someones reply
Hey,
There is a node in Clockwork called Element.Inserts… Maybe have a go and report back?
Cheers,
Mark
Hmm… Would you mind dropping your .rfa on here? so we can test it?
Cheers,
Mark
can you share the test file…only wall with hosting elements…
Hello
an solution with Python
import sys
clr.AddReference('RevitAPI')
#Get Important vars
app = uiapp.Application
element = UnwrapElement(IN[0])
fec = FilteredElementCollector(doc).OfClass(FamilyInstance).WhereElementIsNotElementType().ToElements()
fec = [x for x in fec if x.Host is not None]
OUT = [x for x in fec if x.Host.Id == element.Id]
For me its working…
@robert12546358
I edited the script try it
Thanks for give me a answer
Hi c.poupin
i have one query about this topic.
problem is more than 2 wall is not working in python script, single wall is working.
i have use more than 2 wall in python, so how to use this?
please suggest me
hello @robert12546358
try this (fix with multiple input)
import sys
#Get Important vars
toDoList = lambda x : x if hasattr(x, "__iter__") else [x]
elements = toDoList(UnwrapElement(IN[0]))
out = []
for elem in elements:
temp = []
for e in fec:
if e.Host.Id == elem.Id:
temp.append(e)
out.append(temp)
OUT = out
it’s working.
Thank you c.poupin
