How to find Elements.Types
Hi all, I’m a really new user on Dynamo. I’m trying to copy an exercise but i can’t find the command: Elements.Types (Input: Element(s) - output: Type(s)); i mean also if i type on the search it doesen’t appear; i’ve already tried to open every command with “type” on its name.
There is also OOTB node Element.GetType.
Yes, i’m really sorry, becuase most of the time i’m only copying from the image! :slight_smile:
Thank you Kulkul! I’ll try it!
Fine… I’m getting even more confused now!
Yes i want to get the type to connect to the “list-input”. What i can’t find is the node itself called “Elements.Type”
Oh, thank you! I’ll look for it!
Ok! Thank you agaim, also for the patience! :slight_smile:
Hello, I have the same Problem. :slight_smile:
Can’T find the Elements.Type Node.
What ist the OOTB ? Is it a package?
COuld not find it.
OK, I got it.
In Dynamo 1.32 its name is Elements.Type
OOTB: OUt of the box.
The name is JUST: Type
Hi All,
There is a video showing how to get element types by category below.
Dynamo - Get Element Types by Category in A Model
Hope it is helpful! :slight_smile:
If anyone is looking, the node is called Element.ElementType in Revit 2021 version.
