Elements types node
Hi, which package is the element types node for rebar shape? I dont seem to have it
Element types node is out of the box, but some types were added in different/later versions.
This ine has a drop down. In my revit the RebarShape is in category not type
The OOTB node is Element.ElementType
Im looking for the one in the photo I sent
Not sure, but isnt it just a ootb node…think the reason you get empty list with category node is you dont have some off them insert in model
Ah, I see now, you were inquiring about the All Elements of Type+ node. That one is from the clockwork package. Also, if you are in Dynamo 2.13, be sure to install the IronPython 2.7 package to use it.
@technitutors I believe you are looking for the DSRevitNodesUI.ElementTypes and DSRevitNodesUI.ElementsOfType OOTB nodes. These have been given new names in the latest Dynamo release. Try searching for “Element Class” instead of “Element Types” and “All Elements of Class” instead of “All Elements of Type”.
