I’m having problems in how to be able to edit a windows ‘mark’ parameter by figuring out what room the window is in and grabbing that information and adding it into my ‘mark’ parameter.
Trying to save myself from a very tedious task of manually having to edit the parameter with the room id in it.
I wasn’t able to get Clockwork one to work for me, but I’ve just become stuck on how to proceed. I’m new to Dynamo so still trying to figure things out.
Using a package called Crumple for the phases and collection.
selection by categories lets you select which windows you want to use. (there is a lsmall fininsh box you press when done easy to miss its above your properties/projectbrowser window in revit).
also uses clockwork Room.Windows it requires you to feed the actual phase and not just the name.
