Hi there !
I hope everyone is ok
I have a question about drawing areas inside a room. Let me explain it.
I have a surface of 100 m², and I want to fit it inside a combination of many rooms around a point. I know I can detect rooms boundaries inside dynamo (if it’s usefull…), but I’m looking for an idea to let dynamo draw a piece of area inside another room (not the whole room) to get me to 100 m².
I hope that makes enough sense? let me know if it’s not.
Thanks you all
Mickael
The request sounds like two separate things?
Fitting rooms around a point in a fixed surface (like tetris) - Sounds like generative design is what you’d want to research. There’s been a lot of forum topics, AU presentations, and webinars over the last 4 years that can start to point you in the right direction.
Draw a piece of area inside a room - That sounds like you just want to draw a polygon of fixed area.
thanks for your answer. Yes, it’s more the second thing. I actualy have an area of a certain surface, and I want to fit it in a room, or in many rooms and draw it…
