Hi
here 2 examples with Python
- solution with
OleDbConnection(work with all pyEngine but only on Civil3d)
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.EditorInput import *
# Import references from Civil3D
clr.AddReference('System.Data')
from System.Data import *
from System.Data.OleDb import *
clr.AddReference("System.Reflection")
from System.Reflection import BindingFlags
def read_excel(fileName):
dt = None
connectionString = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" + fileName + ";Extended Properties=\"Excel 12.0;IMEX=1;HDR=NO;TypeGuessRows=0;ImportMixedTypes=Text\""
with OleDbConnection(connectionString) as conn:
conn.Open()
sheets = conn.GetOleDbSchemaTable(OleDbSchemaGuid.Tables, ( None, None, None, "TABLE" ))
with conn.CreateCommand() as cmd:
cmd.CommandText = "SELECT * FROM [" + sheets.Rows[0]["TABLE_NAME"] + "] "
adapter = OleDbDataAdapter(cmd)
dt = DataTable("DataXls")
#adapter.Fill(ds)
adapter.GetType().InvokeMember("Fill", BindingFlags.InvokeMethod , None, adapter, (dt,))
return dt
editor = adoc.Editor
dataTable = read_excel(IN[0])
with adoc.LockDocument():
with adoc.Database as db:
# Place your code below
pr = editor.GetPoint("\nEnter table insertion point: ")
if pr.Status == PromptStatus.OK:
tb = Autodesk.AutoCAD.DatabaseServices.Table()
tb.TableStyle = db.Tablestyle
tb.NumRows = dataTable.Rows.Count
tb.NumColumns = dataTable.Columns.Count
# tb.SetRowHeight(3)
# tb.SetColumnWidth(15)
tb.Position = pr.Value
for i in range(dataTable.Rows.Count):
for j in range(dataTable.Columns.Count):
tb.SetTextString(i, j, dataTable.Rows[i][j])
tb.GenerateLayout()
bt = t.GetObject(adoc.Database.BlockTableId, OpenMode.ForRead)
btr = t.GetObject(bt.get_Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
btr.AppendEntity(tb)
t.AddNewlyCreatedDBObject(tb, True)
# Commit before end transaction
t.Commit()
OUT = 0
- solution with
pandas(work only with CPython3)
import pandas as pd
df = pd.read_excel(IN[0], header=None)
df = df.fillna('')
tb.NumRows = len(df)
tb.NumColumns = len(df.columns)
for i in range(len(df)):
for j in range(len(df.columns)):
tb.SetTextString(i, j, df.iloc[i,j])
tb.GenerateLayout()
t.Commit()
OUT = repr(df)
be careful the line in the header of the Autocad table corresponds to line 0 so it may be necessary to add a blank line at the top of the Dataframe or Datable
