How to create a Range with Multiple Step values?
Hello everyone,
I have a small problem in the logic of my script. I want to split a line by distance in my script.
For example every 3 meters the curve, then every other 3 meters and so on).
The catch however, is the fact that these 2 numbers (3 & 3) are input values, so they can be whatever number i need. So 1 & 3 and 3 & 9 are also inputs which should work.
I was thinking about using a code block with something like this, but i couldn’t figure out how to use multiple distances:
Thanks in advance!
  • Daan
Hi @Daan,
Something like this?
DoubleStepSequence.dyn (9.2 KB)
Option - 1
sumNums = IN[2] + IN[3]
start = IN[0]
sum = start
rangeList = [start]
x = IN[3]
while sum < IN[1]:
	x = sumNums - x
	sum = sum + x
	if sum < IN[1]:
		rangeList.append(sum)
OUT = rangeList
Option - 2
inputs = IN[0].split("..")
def num(s):
    try:
        return int(s)
    except ValueError:
        return float(s)
sumNums = num(inputs[2]) + num(inputs[3])
start = num(inputs[0])
sum = start
rangeList = [start]
x = num(inputs[3])
while sum < num(inputs[1]):
	x = sumNums - x
	sum = sum + x
	if sum < num(inputs[1]):
OUT = rangeList
dashed.dyn (15.9 KB)
Or a line of Design Script
List.Transpose([0..#c..(a+b),a..#c..(a+b)]);
dashed_2020-07-06_11-37-02
@Vikram_Subbaiah & @AmolShah
Thank you very much for both solutions!
I will try both out and see which ones work best for me!
Thanks again!!
First of all, both solutions work great if i have a single input, but the problem is that it is almost always possible that i have multiple curves which need to be split like this.
This is what i have so far, maybe you guys know how to improve this :slight_smile:
Try making it a custom node. :slight_smile:
A Custom Node? How would i approach that/ use that?
(I have never made a custom node btw)
List.Transpose(List.Transpose([0..#(lgt/(lin+gap))..(lin+gap),lin..#(lgt/(lin+gap))..(lin+gap)])<1>);
dashed2.dyn (11.2 KB)
This will help with that: Custom Nodes | The Dynamo Primer
Hey Vikram, my solution wasn’t fully working for me because i need to start at “line” instead of gap, but when i try to use your method, the last line gets cut of, but it could still fit.
Also i need the line to be created, even if the line is not the full length (example, if 1 meter line doesnt fit, but 0.5 does, use 0.5 as length for the last line.
The definition below should address that, but it could sometimes try to create a line of 0 length at the end. You’ll need to extend and improve the definition to eliminate such issues
dashed3.dyn (11.2 KB)
List.Transpose(List.Transpose([0..lgt..(lin+gap),List.AddItemToEnd(lgt<1>,(lin..lgt..(lin+gap))<1>)])<1>);
Small update: i now know how to create custom nodes :slight_smile:
I used your first Python script inside a custom node and it works perfect !
