Hi, @Draxl_Andreas
I want to set the start and end inputs like these: [609-1445] [2657.5-4962.5] [6175.5-8809].
But as you see in the picture, only [609-1445] inserted into the start and end
What does your step input look like? What happens if you change the lacing to auto and remove the list levels like in you example?
@Nick_Boyts
Hi,I changed the lacing to auto and removed the levels, but still doesn’t get what I want.
Your list structures don’t match. Your step is a list of a single item, so it matches the other inputs but only has one value so you only get one iteration. Reduce the step input to a single item.
@Nick_Boyts Thanks! I found the solution.
