Hello.
I am trying to learn PythonScript within dynamo and ran into a problem.
It happens that I want to create a range with data as it was done in a CODEBLOCK but it happens that it gives an error and it only admits integers on the other hand I cannot place quantity limits with the “#” either and it becomes a problem I thought it would be as simple as in the CODEBLOCK.
My request is how could I create a FUNCTION in PYTHONSCRIPT that allows me to enter integer and decimal values as well as allow me to enter quantity limits… in a nutshell, how could I replicate the function that the codeblock has in terms of ranges…?? ?
I leave some reference images there… I haven’t started anything CODE because I don’t understand how I should start… thank you very much for your help.
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
start = IN[0]
stop = IN[1]
step = IN[2]
OUT = range(start, stop, step)
You need to click on “+” in the python node to create 3 inputs and connect your values (start, stop, step) accordingly.
A good start with python in dynamo is this:
you can build custom generators (works on both engine)
drange
import sys
def drange(start, end, step):
i = start
while round(i, 10) < end:
yield i
i += step
OUT = list(drange(IN[0], IN[1], IN[2]))
linspace
import sys
def linspace(start, end, num):
step = (end - start) * 1.0 / num
i = start
yield i
i += step
OUT = list(linspace(IN[0], IN[1], IN[2]))
or you can use numpy with CPython3
