How to create a FilteredElementCollector in C#
Hello
i stuck, in the structure i think, AI is missleading
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Collections.Generic;
namespace MyDraxl
    public class Doors
        public static IList<Element> GetAllDoors(Document doc)
            // Collecting door elements in the entire document
            FilteredElementCollector collector = new FilteredElementCollector(doc)
                                                    .OfCategory(BuiltInCategory.OST_Doors)
                                                    .WhereElementIsNotElementType();
            // Convert the collector to a list of elements
            IList<Element> doorElements = collector.ToElements();
            // Return the collected doors as a list of elements
            return doorElements;
Where i get stucked ?
i want just listed my doors in the current project
These are the changes I would make to your code
using Revit.Elements;
namespace MyDraxl
    public class Doors
        // hide the overall class so you don't get the node Doors.Doors
        private Doors(){}
       //better to change the code to just get the current document, instead of having an input
        public static IList<Element> GetAllDoors(bool refresh)
            // get the current document
            Autodesk.Revit.DB.Document doc = DocumentManager.Instance.CurrentDBDocument;
A recent experience with ZT helped me understand the need to hide some objects (variables, methods, classes)
I finally partly understood why there were so many non-public objects in the Dynamo API
a ninja dynamo Zero Touch Node coder :laughing:
@john_pierson ,
revit does not exist, which module or reference is missing?
@c.poupin ,
i want only the current document, nothing else, even chatGPT is talking about anything
@Draxl_Andreas
add this
using RevitServices.Persistence;
Visual Studio should suggest this as a fix
DynamoVisualProgramming.Revit nuget package
no
it is the latest version of visual studio
the example “this” i got from RevitAPI page…
Need to add this package(s)
@john_pierson ,
here is a issue about Net.8
i did not even run revit, because i have no solution for now
I think that is ignorable for the time being as I reference those same ones with Rhythm
@john_pierson
:drum::drum::drum:
solution trail and error no red underlines … i will see
@john_pierson
it is not exactly what i want but ok
// using Revit.Elements;
namespace MyDraxl
    public class Doors
        private Doors() { }
        public static IList<Element> GetAllDoors(bool refresh = true)
That is great progress. The last part is to Wrap or Cast the element to their Revit.Elements.Element counterpart.
That is the ToDSType(true) portion of C# Dynamo nodes
@john_pierson
So i can not set to private to hide the input, the node itself disappears … hmm
private Doors() { }
private static IList<Element> GetAllDoors(bool refresh = true)
I Typically handle this (wrapping) with something called a Lambda in C#:
Don’t set that one to private. Just the first part. Apologies if I messed that up.
It should read as follows:
@john_pierson ,
enough talk… for tonight
Thank you
@john_pierson ,
it works, but i am not fully aware what i do… :wink:
using System;
using System.Linq;
using Dynamo.Graph.Nodes;
namespace MyDraxl
    public class Doors
        private Doors() { }
        public static List<global::Revit.Elements.Element> GetAllDoors(bool refresh = true)
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            List<global::Revit.Elements.Element> elems =
                new List<global::Revit.Elements.Element>(collector.OfCategory(BuiltInCategory.OST_Doors).ToElements()
                    .Select(e => e.ToDSType(false)));
            return elems;
this sentence, what i am doing here:
In that sentence, you are saying that it is okay to have the method public, but the overall class should not be
