I tried to create a study in dynamo by adding a file path of my dyn file but I don’t have the dependencies directory of it. It’s a sample file dt_generativeToolkit_PackingRectangles_BAF.dyn provided by refinery toolkit for which I want to genrate multiple designs for it but I don’t have the directory.
Would you like to tell me how to generate it ?
Thank you for your answer,
Amel
You need to prep the graph by setting the properties correctly. I recommend reviewing the help documents for your relative Revit release. This is for 2024: Help
You can likely find 2023, 2022 or 2021 by editing the url (change 2024 to the respective year). I do not recommend you start any work in 2021 as it will likely no longer be supported before you see any return on investment and 2022+ are much more powerful.
