dialog = TaskDialog("Header")
dialog.MainInstruction = "Hello, Revit!"
dialog.MainContent = "This sample shows how to use a Revit task dialog to communicate with the user." "The command links below open additional task dialogs with more information."
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1, "View information about the Revit installation")
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2, "View information about the active document")
dialog.CommonButtons = TaskDialogCommonButtons.Close;
dialog.DefaultButton = TaskDialogResult.Close;
dialog.FooterText = "<a href=\"http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975 \"> Click here for the Revit API Developer Center</a>"
dialog.Show()
OUT = dialog
CPython3 engine use a PythonNet bridge (for .Net) and the overloading (overload methods) in current version of PythonNet (2.5) don’t work very well, seem fix in future version (3.0)
from System.Reflection import BindingFlags
#dialog.Show()
arguments = []
ResultDialog = clr.GetClrType(dialog.GetType()).InvokeMember("Show", BindingFlags.InvokeMethod , None, dialog, arguments)
OUT = ResultDialog
