Controlling a Newline and Window Size of TaskDialog (in Japanese)
Hello, Dynamo fellows.
I have shown myself here to ask you whether there is the way to control the newlines and window sizes used in the TaskDialog widnow.
Thankfully, he @Konrad_K_Sobon showed a simple instruction of constructing TaskDialog with typical methods of RevitAPI.
How to Construct a TaskDialog?
Whereas I am struggling with newlines and window sizes (prbly, newlines would be solved by ‘/n’?).
I could not find “window sizes(height/width)” or this sort of things in the member(property).
Could you guys lend hands for me?
The code I modified differentiates from his when it comes to character (Japanese).
I executed my command with:
dialog = TaskDialog("日本語タイトル which means 'a Japanese Title'")
dialog.MainInstruction = "ここにメインインストラクションを記載していますが、改行とダイアログのウィンドウの高さや幅を調整できないでしょうか。 which means 'I put a main instruction here and I would like to adjust the newlines and the window's height and width of a TaskDialog.'"
dialog.MainContent = "右下の「OK」ボタンを押してください。 which means 'click the 'OK' right down below.'"
dialog.CommonButtons = TaskDialogCommonButtons.Ok;
dialog.DefaultButton = TaskDialogResult.Ok;
dialog.Show()
OUT = dialog
and the result is:
To add a new line within a string in python you need to add “\n” within the text.
It would seem you cannot control the width/height of the taskdialog box that is generated within revit using this(TaskDialog Members).
If you utilised the “DataShapes” Dynamo package this does allow you to, and there is further guidance on this on the forum within other posts.
Thanks for your advice.
Duly noted.
