Welcome to the forum!
If you manually set the parameter to the provided value the same issue occurs, correct?
If so then this is a limitation on how the family is built. You’ll need to either ensure the parameters provided are within the family’s range of allowable values, or modify the family to increase the scope of allowable values.
