HI,
I’m new to Dynamo.
I can not find the build pipeline method.
How does the build pipeline object.
Thank you.
I don’t think any such functionality is available.
Hello Vikram,
You mean can not create a pipe or tube ?
That there are other ways?
You can Create only certain Revit elements like Walls, Floors, Structural Framing… from Dynamo.
The Revit elements that you can create you can find listed under Revit in the library
For most other elements you can access and modify parameters.
That is possible to create a pipe by [Autodesk.Revit.DB.Plumbing.Pipe.Create Method ],
however i am not sure [Autodesk.Revit.Creation.Document.NewPipe Method] is still work or not.
you can see the Building Coder blog for more information.
Johnes:
For pipes and ducts is the same way. You can see this post (with code) for MEP from scratch:
https://scaleid.wordpress.com/2015/08/29/mechanical-from-scratch-using-dynamo/
Regards
Thank you reply!
