How to associate mark value or other parameter to surfaces?
hello, again guys I was working on the script for calculating formwork now it is complete but still missing some data see the below image.
now that I have got the intersected surface and removed them also but how can I associate with an element which generated these surfaces so that it will be easily recognized with elements that surface is and its value finally exporting it to excel with a mark or another parameter.
hello, you draw 4 lines large enough but not too big to intercept from the center of your column then you use this node
https://dictionary.dynamobim.com/#/Geometry/PolySurface/Action/LocateSurfacesByLine
here is an idea to dig
Cordially
christian.stan
Hello @ Could you show your whole graph ? how have you get that surfaces ?
Hi @jazzsharma200 …will you import these surface into revit ? if so you could try directshape or family instance by geometry etc…and then you could write to these elements parameters…
here is an exemple with direct shape…
Hi, here’s a bit more fleshed out answer with the approach mentioned earlier
Cordially
christian.stan
Well I want to extrude it with a parameter and then import it inside revit and able to schedule it also
I added a possible branch via raybounce method.
Column and Beam Formwork Surface
cordially
christian.stan
Can you Share the dyn file also will it work in revit 2021?
Here, you can always try
26 Mars Forum anglais.dyn (93.0 KB)
cordially
christian.stan
thnx bro you did it in matter of hours only from where you learnt dynamo ?
thank you for the compliment, here just like you step by step, it’s full of advice and tips from many people
edit: I learned a lot by consulting Mr. Solamour’s document :+1:from a presentation in Ljubljana in 2018 (bedside book for a while :wink: I often come back to it, it doesn’t hurt)
cordially
christian.stan
I will try this also thank you
