Finaly it worked
i had to replace Yes/No thrue 1/0
I corrected Excelsheet from A,B,C,D2 to 1
And one Syntexerror Opject to Object ![]()
Finaly it worked
Edit, parameter was already in family my bad ![]()
@Draxl_Andreas @GavinNicholls Hi guys,
What am I doing wrong?
Hrm it all looks OK… maybe check out my video on the channel from Monday to see if something isn’t the same. Also try using booleans vs 1/0’s.
Yes it was okay, the parameter was already in my family. My bad ![]()
FYI:
This is a must, when you use “No/Yes” the parameter will add as instance even when you say “no”
Hello! The script is giving an error at the List.indexof level. My Excel file has two rows: the first row contains the parameter names, and the second row contains the values. I would like to modify this script to allow me to choose a family in the model.
you can create a new topic, explain your issue well including screenshots and what you already achived!
KR
Andreas
I would like to create a Dynamo script that performs the integration of shared parameters into existing families in a Revit model. In the Excel file, the first row contains the parameter names, and the second row contains the parameter data. Furthermore, I would like to have the ability to select one of the existing families in the model.
Instead of opening the family documents, this Revit API method can take a family in the project and then open it. The rest of the script should be as per my video otherwise assuming you use the same file structure in Excel.
