How to add points to the edge of the ceiling element
Hello
I want to make slanted ceiling.
I could make slanted geometric surface, but it has to be a ceiling element that has parameters like others.
What I’m thinking to do is:
  1. add points to the ceiling edge
  2. drag down the point, that I just created, to make it look like slanted
to do this, I need to add points to the certain edge, but I cannot find any node.
Is there a node that I missed or any package to achieve what I want?
Could anyone give me a help please?
Thank you.
@claire ,
cailings you have to model clever.
you have to write the correct values…
if you deliver Ifc you can map a slab to IfcCovering.CEILING
thank you for your respond.
However, I want to make it using dynamo node.
