How to add Hangers and Supports Automatically to all to (Pipes , Ducts and Conduits)
Now, it’s working perfectly. I made some changes in hanger family parameters and some dynamo nodes. Thank you very much!
Care to share your graph? It might help others with similar queries.
Here is the screenshot, where I made some changes in nodes
Have you solved this problem @trezatrezasdfzzaeae ?
Can you please suggest where to place the families to get the hangers in the model using the script
we have downloaded the package… which .dll or.ds files needs to be loaded
some blue elements shown on the model, how to hide it
Is the script for automatic placed hangers working.
I get immediatly the next errors:
Which packages do i need to install to run this script.
best regards,
Hi
Can you share the script, because I change the node but get the wrong results.
@jcchan1112 Please find below script
UI Rectangular Duct Hangers.dyn (187.2 KB)
Thank you for your reply
the script is great, but I have some problem such as the hanger not align the duct of bottom
attach the screen cap image and dyn
ThansUI Rectangular Duct Hangers.dyn (145.3 KB)
Hangers are placing at correct location in my project. May be this is due to “Reference Level” from which its calculating “Anchor elevation”. I am not sure about this. You have to tweak in the nodes as per project conditions.
Am getting this error,Can some help me to solve this/
I get this error too, sad! Did you fix it?
What the nodes before Math.Atan?
No, I couldnt fix it.
If you use the 2020 Revit version, you should change Offset into Middle Elevation
I have Changed the Middle Elevation,Sets Anchor Elevation-
Error Message-Am getting like-ELEMENT.SETPARAMETERBYNAME OPERATION FAILED.
No, You just need change in Filters Ducts Below SOG and Duct Offset. Keep begin value in Sets Anchor Elevation.
After Changing Middle Elevation in SOG,I found Small Error,in Sets outside Pipe diameter.
Error is- No Parameter found by the Name.-Operation failed.
