How hide line of pipe system
Hello my friend , i want to hide line of pipe system as bellow
but when in visibility graphic remove tick of line noting happen.
it is possible in modify tab (linework) with invisible line. but it’s take a lot time,
i search in google for do it with dynamo but i can’t find a solution for that.
First, you need to determine where those lines are coming from. If you don’t know what they are or what’s controlling them then you can’t automate hiding them. Once you know what they are and what controls them you may realize you don’t even need Dynamo.
From the looks of it, those are just the rendered edges of the elements. They aren’t part of visibility graphics or any particular object class. They’re just rendered with an element to show a general outline. If your view’s Graphic Display Options are set to use the Shaded or Realistic display Style then you can just toggle this setting off for the view.
Thanks a lot Nick
