I have been wondering how dynamo manages to display geometry preview in Revit, and if this is dynamo exclusive or usable with other tools like pyrevit.
Can someone direct me to more information on how dynamo shows the orange masses/surfaces and points in Revit? Id love to be able to use that some day in some of my pyrevit tools in the side..
I don’t know that I would take the time to build it for PyRevit because of its security and .NET10 support concerns. Building such a tool can both be difficult to build and lead to stability issues with poor wrappers (including a server and an interface where Python implementations can struggle). However if you want to try the classes needed are in the DirectContext3D namespace.
That’s interesting, i wasn’t aware of that.
One of the main things i struggle with at my office is getting people to open up Dynamo, or even Dynamo player. To some coworkers it’s simply too foreign to use, which is very unfortunate since the tools i’ve been making really help the office.
This made me switch to pyrevit for some workflows i made, which was accepted far better. I have been considering just rotating into C# and making an actual company wide addin with a better user interface than Dynamo for the less tech-savvy coworkers and hopefully more stable and safe than pyRevit..
Thank you for your points an the link to the docs, that’s exactly what i was looking for
Alternative solution, you can use AVF
The full add-in would be better from a security and maintenance standpoint, but it’s more work to deploy as you have to push each update not just give a new feature by way of new script. So it’s a trade off.
It’s looking like IronPython2 will be completely dead in 2027, and a LOT of pyrevit relies on that so switching to another tool ahead of the wait for a working build might be advisable (it’s what I’d do anyway).
That said, by not helping users adopt Dynamo you are building a dependency on you for all work. This sounds good (job security), but it usually is the opposite (@Garbage_Collector is on vacation this week and we can’t get his thing to work as we are using links in a non-standard way. sadly we can’t rely on @Garbage_Collector’s tools anymore as they only work 100% of the time when he’s involved, so we’re going to plan on doing stuff manually).
@c.poupin’s post using the AVF is also worth reviewing, as it’s a good alternative and likely easier to implement in a ‘one off’ situation.
Apologies for the late reply.
Good to know about the ironPython issue, luckily still gives me some time to phase out pyRevit at the office..
While I’m trying to help users use Dynamo, it’s one thing to make some coworkers use Dynamo Player, it’s another thing to get users to open Dynamo and tinker with it, some users do, some just don’t. At this point at my office it doesn’t really matter where i build the tools (pyrevit/addin/dynamo) there’s nobody around to change the script if something were to break (luckily doesn’t happen often).
I’m considering a full add-in over Dynamo for some things for the reason that user input and step by step modifications, to me seems easier to handle compared to Dynamo. I love using Dynamo for most things but for others i just don’t really know how to even begin setting it up in a user friendly way in Dynamo. For example:
I want to create a front view of a wall by clicking a face, then click several points to place multiple cross sections across that wall, rename the views, set the crop regions by a default offset from wall BB, add dimensions, change wall colors etc.
While writing this, it sounds doable in my head except for getting the user to first select a face, then select a couple of points on the face, and also as with pyrevit Dynamo would have to deal with a bunch of transactions because we are creating views. (also would like to be able to do it for multiple walls at the same time, so select wall > select points on wall > select another wall > select points on that wall repeat until user says its done, while being able to move section boxes in 3D to find all the walls.)
I’m somewhat conflicted on whether or not to use Dynamo on something like this. I can manage this in PyRevit and with some nice xaml windows you can do some pretty fancy stuff for user inputs, in Dynamo the user input just seems lacking for such uses..
Honestly what you are trying to build should be an add-in. PyRevit will take 4x more effort to maintain and has significant hurdles over that, and the ease of authoring and maintaining in Dynamo would be equally difficult as it isn’t built to ‘take an after the fact input.
That said switching the way you approach this could simplify things quite a bit. I am 90% sure you could select points on a face directly and skip the sequential input. If the user selects points on one face you generate the elevation and the section(s) on that face. If they select points on multiple faces you generate the elevations and sections for each face and point combo.
This would reduce the number of clicks from the users, and also make your tool more stable, easy to maintain, and faster I execute.
