I’m trying to pull start and end points from detail lines, and did have it working in an earlier version of dynamo, but it no longer works. Previously I was using Clockwork’s Element.Location node, and it still does what I want, but only with model lines. I’d prefer to keep using detail lines because they are view specific and wouldn’t require management elsewhere in the model.
Questions
Is there a way to pull start and end points (xyz) from detail lines? I’ve tried every curve node I can find, and none work with detail lines.
If that isn’t possible is there a way to convert detail lines to model lines and vice versa, to allow me to convert the lines, pull the points, then change them back to detail lines?
