Clicky ID Pop Up
Hi! Can anybody help me ? I need a window pop up with that IDs , that you can click on the green part and it would take you to that element.
This will do it for you.
This wasn’t make by me, you can find all the source documentation here;
Python Script
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class FormResume(Form):
        def __init__(self, lstElems):
                self._lst_Elems = lstElems
                self.InitializeComponent()
        def InitializeComponent(self):
                self._listView1 = System.Windows.Forms.ListView()
                self._buttonQuit = System.Windows.Forms.Button()
                self.SuspendLayout()
                # listView1
                x,y = 294, 379
                self._listView1.Anchor = System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right
                self._listView1.Location = System.Drawing.Point(13, 33)
                listViewItem = []
                for elem in self._lst_Elems:
                        item1 = System.Windows.Forms.ListViewItem(elem.Name)
                        item1.Tag = elem
                        listViewItem.append(item1)
                self._columnHeader1 = System.Windows.Forms.ColumnHeader()
                self._columnHeader1.Text = "Liste Elements"
                self._listView1.BorderStyle = System.Windows.Forms.BorderStyle.FixedSingle
                self._listView1.CheckBoxes = False
                self._listView1.Columns.AddRange(System.Array[System.Windows.Forms.ColumnHeader]([self._columnHeader1]))
                self._listView1.GridLines = True
                self._listView1.Items.AddRange(System.Array[System.Windows.Forms.ListViewItem](listViewItem))
                self._listView1.Size = System.Drawing.Size(x,y)
                self._listView1.View = System.Windows.Forms.View.Details
                self._columnHeader1.Width = x
                self._listView1.ItemSelectionChanged += self.ListView1ItemSelectionChanged
                # buttonQuit
                self._buttonQuit.Anchor = System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right
                self._buttonQuit.Location = System.Drawing.Point(226, 418)
                self._buttonQuit.Name = "buttonQuit"
                self._buttonQuit.Size = System.Drawing.Size(81, 30)
                self._buttonQuit.TabIndex = 1
                self._buttonQuit.Text = "Quit"
                self._buttonQuit.UseVisualStyleBackColor = True
                self._buttonQuit.Click += self.ButtonQuitClick
                # FormListView29
                self.ClientSize = System.Drawing.Size(319, 460)
                self.Controls.Add(self._buttonQuit)
                self.Controls.Add(self._listView1)
                self.Name = "FormResume"
                self.SizeGripStyle = System.Windows.Forms.SizeGripStyle.Show
                self.Text = "FormResume"
                self.ResumeLayout(False)
        def ButtonQuitClick(self, sender, e):
                self.Close()
        def ListView1ItemSelectionChanged(self, sender, e):
                elem = e.Item.Tag
                itemId = elem.Id
                uidoc.ShowElements(elem)
                uidoc.Selection.SetElementIds(List[ElementId]([itemId]))
objForm = FormResume(UnwrapElement(IN[0]))
objForm.Show()
I’m sorry . I’m new to dynamo and i have no idea what to do with that code :sweat_smile: isn’t there a way to solve this using nodes? :melting_face:
No sir.
Use it like this. (My Python node is re named here)
  1. Copy the Python code from above into a Python node.
  2. Your input is the list of elements that you have shown above.
When you run that with the list of elements, you will be given a popup window shown int he screenshot and you can click between them like you want.
i think its not working
No copy it into a “Python Script” node
WORKS PERFECT! LOVE IT. THANKS! :star_struck:
