How do get the value of the pipe type name?
Hi
If I use two nodes “PipeTypes” and “getName”, then the values of the pipe type names are output. However, when I try to transfer the code to one node, I get nothing. I need to get the values of pipeline type names in one node. What am I doing wrong?
P.s. I’m trying to use the getName function from the Clockwork Element node.Name+.
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Plumbing import *
def GetName(item):
	if hasattr(item, "Name"): return item.Name
	else: return None
pipetypes = FilteredElementCollector(doc).OfClass(PipeType).ToElements()
if isinstance(pipetypes, list):
	OUT = [GetName(x) for x in pipetypes]
else: OUT = GetName(pipetypes)
@Kungur ,
what do you need more ?
clr.AddReference('System')
elements = UnwrapElement(IN[0])
output = []
for i in elements:
	output.append(i.Name)
OUT = output
or just codeblock
KR
Andreas
Thank you, Andreas!
I need to get only one Python script node, , in which I will get the names of pipe types. I need only Python solution, without standard nodes Dynamo.
Why?
you will have error if you use pipe.Name
you can use:
name = Element.Name.GetValue(pipe)
Thank you very much! It is working.
typesnames = []
for p in pipetypes:
	name = Element.Name.GetValue(p)
	typesnames.append(name)
OUT=typesnames
