How can I connect Point clouds(rcs-rcp) with Dynamo in Revit?
Hello, I’ve been attempting to identify errors within the point clouds using Dynamo scripts or Python script.
Although I’ve imported the point clouds into my project, I have been unable to locate the point cloud elements within the Dynamo library or packages. Also, I am uncertain about the correct procedure for connecting the Python script to the point clouds. If anyone is working with point clouds and has valuable advice, it would be greatly appreciated. Thank you!
look into the Sastrugi package from @Ewan_Opie. There are several topics on the forum for it and how you can work with point clouds from Dynamo already on the forum.
Thank you!
