Dear All,
I want to generate an array profile on the draw rectangle?
Kindly suggest me what should I do?
Thanks,
Dear All,
Thanks,
Add a second range input to the Y value of the geometry.translate node and set lacing to cross product.
Thanks @Vikram_Subbaiah
how do we do this for a rectangle or a hex ?
Take the same graph and add this node off the end: Dynamo Dictionary.
Thank you, But How to control the orientation?
Not sure what you mean. Can you post a sketch?
That would do it.
It’s be more efficient to create one point, use that to create a circle, then a polygon, rotate said polygon, then array the polygon with a Geometry.Translate node with cross product lacing at the very end of the graph.
Reason being is the count of objects - you deal with a single item until the last node so instead of 4*n objects you have 4+n objects.
