I already extracted to excel some informations that I wanted but Im trying to add a column for coordinates x and y but I dont know how to do it, any suggestions?
(im a new user so I cant upload documents)
Which part are you stuck on?
Also, when sharing an image, always make sure your node previews are pinned so we can actually see the data you’re using. Otherwise we have no idea what’s actually going on.
New folder (2).7z (1.2 MB)
Hi Check the Dynamo Code in the folder, hope it will sove your problem.
Objective of the Code:
INPUT: Point Coordinates (X,Y) from Excel sheet:
Select an Alignment
Output: It will export (Station, Offset, X,Y coordinates values) to an excel sheet:
Regards
Babulal
