I using the HostedInstance by points node from Spring but it is only allowing me to place 1 hosted object per wall. Even if i play with the lacing
Unfortunately, this node does not support lacing. Below is an image from the repository’s sample file. You basically need to count the points on each wall and repeat the wall element for each window point because each window needs a host.
Thanks Dimitar for your response. where is the Repository found
Could you please tell me in which package this node is?
This is from spring nodes and this topic is from a while ago. I’ve reworked the input definitions since then and you should have more control over the lacing.
