After you demo the existing window and paste a new window in same place.
Change the new window type to your replacement and run this to correct infilling wall errors.
At the moment just copying window instances and pasting to another phase doesn’t work.
Is there a way to read all the existing windows, find there location, then creating new versions in the new phase?
Creating a new family instance seems to work manually.
Copying them and attempting to paste in the same place on the new phase gives me the error "Instances not cutting anything"
When I place a new instance of the window on the new phase, in the same place, it works.
That’s why I was thinking of placing all new families.
I just published a package that has 3 nodes related to windows and doors called DominaDynamo. It would allow you to do what you are trying to. The only issue (and it could be a big one) is that it is ready for Revit in Spanish and you would have to change all the nodes that have to do with the name of revit parameters (usually between quotation marks).
I´ll show an image of the script I just tried and works.
I´m sorry, I am still working on the webpage and it´s not ready yet. It will be a page with utilities, information and courses about Dynamo in spanish. You can download the package DominaDynamo from the Package Manager but as I said you would have to modify many of the nodes to make them useful in the English version of Revit.
In line 54 you have to change where it says “Altura de antepecho” by “Sill Height” (in any other version the name of that parameter). I think it should work that way. Plese, let me know.
Your sequence should be fine. The node looks blocked although i suppose you have tried it with the node activated.
You could try to;
1 Doubleclick on the node,
2 Copy (ctrl+c) everything inside
3 Paste it in your script
4 Link the wires to the corresponding input nodes. Then run the script and see what is going wrong.
That method has helped me many times when custom nodes don´t work…
