Hello!
I need some guidance with this node. I am trying to feed into the host port multiple walls. I am experiencing odd results when doing this. Can anyone provide some thoughts or clarity on adding families to multiple walls? Thanks!
Are the lists you are inputting the same length? That may be the first thing to check.
If that is not, can you show us the rest of your graph? We need to see what is going in.
Have a look at the sample file here:
It’s a little old but should point you in the right direciton.
I am unable to open this .dyn file.
