I made a lot of sections (100+) to detailing foundation beams these beams connect against each other.
If i rebar these beams (in view) also the rebar from intersecting beams are visible.
What i want to make is the rebar in these sections invisible with Element Hide or View Visibility States using Dynamo.
I don’t know where to begin to identify these sections can you help me to start.
Thnks Edwin.
clr.AddReference("RevitAPI")
import System
document = DocumentManager.Instance.CurrentDBDocument
uiDocument = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
view = uiDocument.ActiveGraphicalView
instance = UnwrapElement(IN[0][0])
def HideElements(view, instance) :
ids = List[ElementId]()
if not instance.IsHidden(view) and instance.CanBeHidden(view) :
ids.Add(instance.Id)
TransactionManager.Instance.EnsureInTransaction(document)
view.HideElements(ids)
return None
instance is the rebar element if you want to hide multiple rebar element iterate through a loop.
