Hi, I want to create a dwg from a shp file
How I can create a dwg from a shp file
What have you tried, and are you using Dynamo? We need more specific information and evidence of what you have tried - the forums are not a resource to do all the work for you.
There are various apps and integrations out there which can convert these such as arcGIS. I don’t believe there is a default node/method available in Dynamo that does this simply:
https://library.carleton.ca/guides/help/converting-shapefiles-autocad-drawing-files
If this is just an export/import question I’d recommend asking the AutoCAD or Revit forums.
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-841D4FC6-3625-4B77-87C0-A95D74047E00#:~:text=To%20do%20so%2C%20use%20the,selected%20files%20from%20the%20list.
