Excuse my English as a translator.
I have a problem when I want to make a routine with if else and elseif.
I want to do the following:
I have three lists “Columns”, “Plates” and “Columns and plates” and at times I have a list either plates or empty columns, for that reason I am using the IsEmpty node to be able to filter it and when I have that case I pass a list now be plates or columns and if I do not have any empty list, let the two lists pass, but when I write the routine in the last lines of code it gives me an error in code block, I don’t know if I am placing the syntansix correctly or my error is something else I would appreciate it if you could give me an answer to this problem, thank you.
tarrajeo v1.dyn (75.5 KB)
