I’d like to use visual studio to write python scripts for my dynamo nodes. However, I’m not able to get the intellisense to recognize the Revit API. Typically when writing a python node in dynamo I start with clr.AddReference(“RevitAPI”).
Does anyone else work in Visual Studio? can you offer some advice in getting my references set up correctly.
Thanks,
Nate
Sorry this never took off @Nate_Holland . I’m in the process of exploring the very same question and will respond when I learn more. The IDE of Visual Studio is ideal to maximize productivity. Having a live link back into Dynamo would be sweet to get the feedback on how to adjust a scripting approach as you go. Since Python is procedural I could see it working while C# might require a build each time. I hope to make this workflow happen as well!
Best,
Tim
