Hi Guys,
With Object.ByGeometry the result gives ‘null’. I have already uninstalled and reinstalled my C3D. I can’t see the Object in my model space. Does anyone know what to do?
Hi Guys,
Hello and welcome…im not a C3D guy, but do you think a list flatten after solid by sweep…could help you here ?
I tried this, list is out of the output of Object.ByGeometry but stays ‘null’.
Can you try a Solid.Volume node and see what the result is?
Hi Daan,
I have set the lacing on shortest and @L1 but still does have ‘null’.
Are you dutch by the way?
Hi @zachri.jensen,
Solid.Volume gives on the Solid.BySweep a normal number. With Object.ByGeometry it gives null…
Are you able to upload the files?
Also, can you clean your %temp% folder and then try again?
I cannot upload because I am a new member on the community. But you can download it threw the link below.
@UT_CIW please change the Geometry Scaling back to Medium and try again.
I tried, but still gives ‘null’. Did you see anything in the file?
Ja!
Could you try flattening the output from the Solid.BySweep node?
A true lifesaver…
I don’t know when I ever will learn to clean the temp folder ![]()
Excuse my out of the blue question.
If Solid has no volume (0), does that mean that the Object.ByGeometry node cannot write out a block?
