Now I have another problem, in this case of a nature of lists and associations. As mentioned, the objective is the representation of degradation. From the starting dwg the cracks, stains etc. are represented on the respective layers. With the bimorph node I can have a list of all the lines present in the layer, but not divided by polylines. Has anyone faced similar situations?
Should I create another post for this request?
Hi @Salvatore_Falcone ,
Split of the topic for you since this is more about a different issue you’re having.
In the Springs Nodes Package there is a node that lets you group geometry by distance, you could use that to group your curves to then make polycurves from them.
