Having trouble changing the View Name? says "Dereferencing a non-pointer"
Hello, I am having trouble changing the View Names? The error says “Dereferencing a non-pointer”. What does that mean? How do I fix it?
I don’t get this warning, did you try any other inputs?
I tried the element types input.
And for parameters?
view name is the only parameter that I need right now. Im not sure I understand.
I think you need to find out where the error come from since it should be working and it’s not, so I just advise to do some basic tests at first…
@mix @Yna_Db Its because list contains “null”.
Is there a way to filter out the nulls?
@mix follow my first image to filter nulls. I already showed that.
