Hi guys, i am working on a script that calculates the total impervious and pervious areas. Areas that intersect are also calculated and reduce accordingly. Everything works well if the areas area created with lines boundaries but if they have arcs, things behave totally different. any ideas? thanks.Areas.dyn (77.5 KB)
Hi Paolo,
I was running version 1.0.12. i just updated to the new version 1.0.13 and same thing. i added and area with multiple arcs shapes around and gets worse.
areas.dwg (486.2 KB) Areas.dyn (83.3 KB)
Paolo, i tried in a different computer with the same results. We are running civil 3d 2020.2 update dynamo core 2.4.1.6394, dynamo civil 3d 2.4.1.2161 and the the attached packages installed in dynamo.
Hi @Paolo_Emilio_Serra1, I have been having issues using the Toolkit for hatch geometry as well. Can you please take a look at the attached files? I am using Toolkit v1.1.8.
Hatching.dwg (477.4 KB)
Hatching.dyn (7.6 KB)
