I have a question regarding Handrailings in Dynamo. I want to create a Railing on top of a solid by defined Points (or lines/curves if needed…). I tried it by AdaptiveComponent.ByPoints, but I get the error “The argument have issues”.
Is there a way where you can define Point A and B and then generate a full handrailing between these given points? Or how does this work?
I create some Points. Add the railing posts (which are working). Now I want to add the handrailing… I tried creating them equal to the posts just swapped the column for a beam.
When you draw a beam in Revit, do you draw it as a polygon or as a line?
Try a Polycurve.ByPoints node, followed by a Polycurve.Curves or Geometry.Explode node, and feed that into your Beam.ByCurve.
I will also point out that this will make a beam, not a handrail, so you may have some issues with graphic display. Having some issues with the online api docs sites at the moment (might be my phone, might be the site), so I am not sure if a real handrail is possible.
What doesn’t work for you? Post some further explanation, a an RVT file showing what you have vs what you want, and the dyn you are using.
I don’t recall seeing it, but that doesn’t mean it doesn’t exist. Just that either I don’t remember, and/or haven’t seen it yet, or that it doesn’t exist. As a first step you need to check the API to see if it is doable, and as I noted above I am unable to check if this is in the API completely at this time so it’s unclear.
Perhaps the site will load completely for you:
Look over what you see there (or in your Revit version if 2020 isn’t your thing yet) and see what options you can find for creating a rail.
