Hand Orietation of Steel Connection Revit
Hi Guy!
I’m trying to create a script that create many section views of a selected steel connection,I found here in forum,The script called “Element View Generation”.(Link 1),Its work fine to other type of elements,when I tried to use in Steel connection the problem with Hand orientation Started.
I had tried to use the clockwork node(Familyinstance.handorietstion),orchid,but every has failed.So someone has any idea of how I can find a solution?
Link 1:
