Hi John, I have been struggling with a problem and I think it is super easy.
I have this list of 545 elements contained into individual bounding boxes. there are 152 bounding boxes and to each one I have assigned a code (quadrant number) how can I rearange the elements in a way I can rename them with the corresponding quadrant number?
Might need a new topic. But, you should be able to group by key.
The key would be the BOUNDING BOXES node and the list would be the elements.
@narella1 continue here
PLease post any relevant files or more info
Thanks!!!
Make lists the same lengths
I have to change the “Mark” of every door at my project with a code created by the intersection of 2 grid lines (ie: B+21 = B21) the “QUADRANT NUMBERS” are the intersection numbers and they are related to 152 points with which I created 152 Cuboid that turned into Bounding boxes. There are 545 doors contained into Bounding Boxes. I want to give to each door the number of that corresponding Box. I know that I can Set element by name but first I need to rearrange the doors.
Make a parameter for each door with its location That parameter will be the key when you group by key. Then you can set whatever parameters you want for those groups.
Check out my response at …
