I’m trying to extract Groups from a base file and place them in a new file. I do this by using the IDs of the Groups. Only when I run the node “Group.PlaceInstance” do I get the following message:
Warning: Group.PlaceInstance operation failed.
The call is ambiguous between the following methods or properties: ‘Revit.Elements.ElementWrapper.Wrap(Autodesk.Revit.DB.RoofType, bool)’ and ‘Revit.Elements.ElementWrapper.Wrap(Autodesk.Revit.DB.ScheduleSheetInstance, bool )’
I can’t figure out how to solve this.
@Draxl_Andreas thanks for the reply. I have no experience here. Do you have any tips where I can find more information on how to do this with the data from the website link?
@Andries
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
locationPoint = XYZ(0.0,0.0,0.0)
gT = IN[0]
# 🔓 place it
t = Transaction(doc, "Place Group")
t.Start()
output = []
newGroupType = doc.Create.PlaceGroup(locationPoint, UnwrapElement(gT))
output.append(newGroupType)
t.Commit()
# 🔒 Done
OUT = output
the example works for 1x group
@Draxl_Andreas If I use it separately within the same file it works, but not in my script. it gives the error message below.
File “”, line 32, in
Exception: Starting a new transaction is not permitted. It could be because another transaction already started and has not been completed yet, or the document is in a state in which it cannot start a new transaction (e.g. during failure handling or a read-only mode, which could be either permanent or temporary) .
The purpose of this script is that I can indicate different group types in an Excel file. This contains the ID numbers of the groups that he retrieves from a basic file with the nodes “file path” and “Document.Open” and “Element.ById”. The coordinates are also determined and calculated in the Excel file. these must also be entered for this. If I want to adjust this in the script, this is not possible.
The purpose of this script is to generate housing blocks.
@Andries
output = []
# 🔓🔒🔐 place group
with revit.Transaction("place group"):
try:
except:
import traceback
output.append(traceback.format_exc())
try this
