Does anyone know how to extract or even if its possible through the API to get the geometry of a window part of a curtain panel that includes both solid panels and glazed. Attached are some pictures for reference.
Attached is a sample file…
I was hoping to get vertices of just the window instance but i think i can expand on what you gave me. I was hoping to create an intersection of just the window (ignore all solid wall) with the space geometry solid to simplify some extraction for energy model.
@Arif_Hanif In that case, you should be able to extract Window geometry directly
Translating the location point based on the height and width values should give you the vertices.
