hello guys,
i want to access pipes in the model by using this line in python “ElementCategoryFilter(BuiltInCategory.ost_“the needed element”)” but the problem builtincategory enumeration doesnot has a member for getting the pipes in the model (there is not member called ost_pipes) so how can i access the pipes through the python
Did you try with OST_PipeCurves ?
now i can access the pipes , thank you
You’re welcome.
You can mark the post as solved.
how to mark it as solved?!
It’s been done already.
