Hi everyone,
i have been trying to figure this one out myself but am stuck now.
A brief explanation of my goal:
I created a duct system, used the MEPover node " Elements in connected Network" to get a sorted list of all my elements. I then created two shared parameters; “Number of element” and “GUID previous element”.
I am now trying to get a list of elements of a branch from this network.
I input a starting element in my python node, then check if the “number of element” is != 1 (1 being the first element of the network). If so, get the “GUID of the previous element” and get the corresponding element. Append it to a list and then start all over again with the new element, till i reach the first element.
The functions are working, but i can’t get the loop working. I tried adepting the MEPover to my needs, but i’m stuck there.
I hope i was able to explain what i am trying to achieve and that someone might be able to help me.
My phyton code is added below. If there is an easier way to doing this, i would be interested as well, since i am learning phyton while doing this.
Greetings.
import sys
clr.AddReference("RevitAPI")
import collections
from collections import OrderedDict
ElementList = UnwrapElement(IN[0])
outlist = []
#Definition der Funktion Bauteilnummer; ruft den Wert des Parameters "Bauteilnummer" ab
# Number of Element
def Bauteilnummer(element):
nummer = element.LookupParameter("Bauteilnummer").AsInteger()
return nummer
#ruft Wert des Parameters "GUID nächstes Bauteil" ab; kann noch in Funktion umgewandelt werden
# GUID of previous element
def GUID_abrufen(element):
parameter = element.LookupParameter("GUID vorheriges Bauteil").AsString()
return parameter
def nextElements(elem):
listout = []
IDList = []
if Bauteilnummer(elem) != 1:
IDList.append(GUID_abrufen(elem))
for ID in IDList:
listout.append(doc.GetElement(ID))
return listout
def collector(elem):
cont = 0
for i in nextElements(elem):
if i.Id in lookup:
cont += 1
item = doc.GetElement(i.Id)
lookup[i.Id] = item
collector(i)
if cont == len(elements):
return elem
for x in ElementList:
lookup = OrderedDict()
ownerId = x.Id
collector(x)
outlist.append(lookup.values())
OUT = outlist
