Getting Faces and Solids gives errors for Walls and Floors
Looks like you wrote f.get instead of floor.get in your loop
Cordially
christian.stan
hi, yes you are right, but in this example it does not get a list, but an instance, so the execution goes into the else: part :wink:
You will have to wait for people much more savvy than me in python (super beginner mode but it progresses slowly but surely (today I learned the Sets and the Union and Intersection methods)
Cordially
christian.stan
Hello @danail.momchilov
I don“t know what your goal is.
In this thread was shown, that all problems with converting to Dynamo geometry can be avoided by just using Revit geometry and not converting it at all. So why don“t you just use the Revit geometry like i did? I did not convert it.
Only now I realized what your general idea was… sorry about that, it just took some time… :smiley: thank you for your thread, I think it could really help a great deal, as I have been struggling with this issue for a long time on many of our workflows! :slight_smile:
here’s what I did with floors:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
app = uiapp.Application
opt = Options()
outlist = []
floors = UnwrapElement(IN[0])
for floor in floors:
	templist = []
	solid = floor.get_Geometry(opt)
	for f in solid:
		faces = f.Faces
		for face in faces:
			try:
				if face.FaceNormal.Z == 1:
					outlist.append(face)
			except:
				pass
OUT = outlist
Since I only need the uppermost face of each floor, I would just check all face normals of the floor’s solids and only get the ones that have a Z component equal to 1. Did some testing to make sure I get the correct ones, by building small floors, that are kind of ā€˜wrappable’ (just to be able to visualize it) and it all seems fine :slight_smile:
