Hi , does anyone have any golden nuggets on how I might go about getting all the points in the grid closest to this curve?
There is a node called Geometry.DistanceTo it might be worth a try
Mind the lacing option
Might be better to build a rectangle at each point, and collecting the objects which the curve passes though in the order which they pass (so from parameter 0 to parameter 1). Could be computationally more heavy but I’m not sure.
@jacob.small
Thats the first time i see a Data.Remember node
Can you tell us what it does?
This is from the Refinery beta package. Typically it allows for use of Revit data in Refinery (which has no direct connection). It’s a node which remembers most basic data types. In thus case I had built a big ugly set of nodes to make the Nurbs curve.
@Marcel_Rijsmus you should definitely check out the beta.
@jacob.small
Thnx, but for the time being its olny sandbox stuff i do
I will read, whatever i can find
Even sandbox has a lot of uses. Such as the one I used. Imagine not having to recalculate a long running set of nodes to build a mesh each time you open a graph? Or parsing the data out of a large document so that you get to just the stuff you need faster? Good stuff all around. ![]()
Great node to know about!
So the finished business. closest point achieved. I managed it several different ways but this by far seemed the fastest computationally with circles over squares (also using circles gives a better point closest to management with radius as an indicator) and using a polycurve to intersect.
The issue was I didn’t flatten my curves list.
Thank you for all the help and the reference of useful nodes!
