Hi All,
I was wondering if anybody knew - the GetEndPoint method for the curve class gets the coordinate value based on which point (the survey point or the internal origin)
Appreciate all inputs here ![]()
Hi All,
Hi @adikshit ,
I donโt think there is a direct method to get the world-coordinates of a point, since everything within the Revit project is translated according to the Project Base Point.
You could however extract the xyz-values from your points and the xyz-values of your Project Base Point. Then add them together to get the world-coordinates of those points.
Hello @adikshit and welcome
the GetEndPoint method return point from internal origin coordinate
here an example to return point from different system coordinates
import sys
import System
clr.AddReference('RevitAPI')
class OriginEnum:
Internal = 1
Survey = 2
BaseProject = 3
def get_end_point(curve, index, originEnum):
originEnum -> OriginEnum.Internal OR OriginEnum.Survey OR OriginEnum.BaseProject
pt = curve.GetEndPoint(index)
if originEnum == OriginEnum.Survey:
translatedpointA = doc.ActiveProjectLocation.GetTotalTransform().Inverse.OfPoint(pt)
return translatedpointA
elif originEnum == OriginEnum.BaseProject:
projectPoint = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_ProjectBasePoint).FirstElement()
projectXyz = projectPoint.get_BoundingBox(None).Min
return pt.Subtract(projectXyz)
return pt
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstCurves = toList(UnwrapElement(IN[0]))
pts_survey = [get_end_point(c.Location.Curve, 1, OriginEnum.Survey) for c in lstCurves]
pts_Project = [get_end_point(c.Location.Curve, 1, OriginEnum.BaseProject) for c in lstCurves]
OUT = pts_survey, pts_Project
haha - you solved it all for me
Thanks Cyril
