GetCrossSlopeAtStation method doesn't work in a for loop
I want to list the cross slopes in every round station of my alignment via a python script but I’m struggling with that. For an individual station I managed to make it, but using it in a for loop I always get an error message.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
A = IN[0]   # Alignment
O = IN[1]   # Offset value
S = IN[2]   # Surface
editor = adoc.Editor
with adoc.LockDocument():
    with adoc.Database as db:
            # starting station
            SS = A.InternalDBObject.StartingStation
            # ending station
            ES = A.InternalDBObject.EndingStation
            # sequence from starting station to ending station, incrementing by 1
            r = range(int(SS),int(ES))
            #DesignedCrossSlopeLeft = A.InternalDBObject.GetCrossSlopeAtStation(4444, 1, 0)
            # listing the actual cross slope value in every station
            DesignedCrossSlopeLeft = []
            for i in r:
                DesignedCrossSlopeLeft.append(A.InternalDBObject.GetCrossSlopeAtStation(i, 1, 0)
            t.Commit()
            pass
OUT = DesignedCrossSlopeLeft
A Parenthesis is missing DesignedCrossSlopeLeft.append(A.InternalDBObject.GetCrossSlopeAtStation(i, 1, 0))
