Library for Civil Python
Hi!
What library I should import to use Geometry operation (StartPoint, PointsAtSegmentLengthFromPoint etc.) in my Civil Python script?
I tested plenty of different scripts including default Python template and Dynamo Examples, with no result.
nq1
I suppose something like this might work
nq2
my current Python feedback)
Your input seems to be empty. NoneType…
I believe all my input is fine)
nq3
What you connect to python node, I meant.
In fact, I really got mixed up in my connection nods when I took a screenshot. But it doesn’t matter in this case.
nq4
I’m trying to port my code from Dynamo Revit to Dynamo Civil, and below my civil Python test script. And I realized that a StartPoint function work well
Blockquote
import sys
import math
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AeccDbMgd’)
dataEnteringNode = IN
Alignment = IN[0]
R_Rail_CL = IN[1]
L_Rail_CL = IN[2]
editor = adoc.Editor
i = 25
l = 0
alpha = 0.02
Distance_Check = 0
CS = 0
RP =
LP =
Split_List_R =
Split_List_L =
RCP_List =
LCP_List =
Distance_List =
Split_List_R.append(R_Rail_CL.StartPoint)
Split_List_L.append(L_Rail_CL.StartPoint)
with adoc.LockDocument():
with adoc.Database as db:
        RP = Curve.PointsAtSegmentLengthFromPoint(R_Rail_CL, Split_List_R[-1], 25)
        t.Commit()
        pass
OUT = Split_List_L.append
Blockquote
